Old 09-25-2012   #11
Default Re: Z06 Brakes getting ready for install
Originally Posted by Corbusa View Post
So I guess you have to use 18 in. rims? I'm just curious on what changes had to be made? Thanks for the write up...
I have stock Z06 18/19" wheels. The fronts are 40mm offset but the rotor offset will make that work. I'll show a before and after in terms of fender fit and clearance.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 09-25-2012   #12
Default Some perspective for sizing
The Z calipers needed a bit of modding in order for the adapters to fit. No biggie.
Also a couple of pics showing the size of the brakes relative to the fender opening. These things are pretty big.
Old 09-25-2012   #13
Question?
Will I need to bleed ALL the brakes or just the fronts?
Old 09-25-2012   #14
Corbusa
Get some speed bleeders .It only takes a second to bleed them and a good idea to keep the fluid fresh anyway.
Those Calipers are huge! Nice!
Old 09-25-2012   #15
Interestingly, each side has its own bleeder.
Old 09-26-2012   #16
Now thats a big brake setup! GC
Old 09-26-2012   #17
Looks like I need to "shim" the caliper in order to center the rotor in the caliper.
Haven't checked passenger side yet.
Old 09-27-2012   #18
Here's a pic of the difference in offset for the Brembo and Z06 rotors. Pretty significant which should make the Z06 wheel tuck in nicely. You can also note the difference in thickness.
Old 09-27-2012   #19
mgg
I would definatley bleed the entire system. Start with he right rear, left rear, right front, left front. ATE fluid is not a bad choice. It is inexpensive works well. I have used it in my race car for years. I would suggest the gold color rather than the blue. It is easier to tell if it is dirty with the gold. Hope you like the brakes. Congrats!
mgg is offline   Reply With Quote
Old 09-27-2012   #20
next you will want the 4 piston Z06 brakes for the rear
