Old 09-06-2012   #11
ALZR1
Default Re: 33 Spline
Al,
Excellent design and supurb machine work.
I'm sure these will be the last set of spindles you will be installing.
Which company supplied these?
They do not look like the larger spindles some have got in the past from Summers Brothers out in California.
Base on this setup what component in the drivetrain do you now consider to be your weakest link?
I've never seen summers Bros. Axles or how big of an axle they have.
Someone has made A reproduction of the stock axle from summer Bros. 27 spline out of A billet 4340,but these broke just the same.
AL.
ALZR1 is offline   Reply With Quote
Old 09-06-2012   #12
Paul in VA
Hi Al: Did you make these?
Thanks ... Paul
(Paul in VA)
Paul in VA is offline   Reply With Quote
Old 09-06-2012   #13
Originally Posted by ALZR1 View Post
These axles are pure racing products.
This is an upgrade for anybody that breaks axles.They are beefier the stock axles below the splines at the shoulder measures 1.235".The new axles at the shoulder measure 1.450",and Remember these axles are made out of A much better material.
AL.
Awesome AL ok that makes sense. What a lot of folks do is spend a lot of time and money wise for more horsepower. Its nice to see the transfer links beefed up to take the raw power. Great job.
Old 09-06-2012   #14
Jagdpanzer
Jagdpanzer's Avatar
AL.
Al,
Here is a photo of the Summers Bros 31 spline spindles.
Not nearly as pretty as yours.
And here are pair of 27 spline billet spindles I picked up a while back.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 09-06-2012   #15
ALZR1
I had A company make them for me and I supplied the bearings.
AL.
Old 09-06-2012   #16
Pete
Pete's Avatar
Phil,what hub/bearing you use with the 31 spline axles.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 09-06-2012   #17
Jagdpanzer
Jagdpanzer's Avatar
Al,
After looking more closely at your bearing hubs appears the bolt pattern was re-drilled. Are these hubs from a different car model modified to work on a C4 suspension with your new 33 spline spindles?
Come on Al out with it, inquiring minds want to know
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 09-06-2012   #18
ALZR1
Al,
After looking more closely at your bearing hubs appears the bolt pattern was re-drilled. Are these hubs from a different car model modified to work on a C4 suspension with your new 31 spline spindles?
33 splines not 31.
AL.
Old 09-06-2012   #19
Jagdpanzer
Jagdpanzer's Avatar
Pete
Summers Bros bore out the stock bearing hubs and re broach them for 31 spines. If you go with their setup be sure you have them do up an extra bearing hub otherwise it will be a while getting a spare if you should need one later on.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 09-06-2012   #20
Jagdpanzer
Jagdpanzer's Avatar
33 splines not 31.
AL.
Al,
Sorry, I corrected the post.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
