Old 08-13-2012   #11
Default Re: clutch engagement; early
If slave seals were in wrong, I would have fluid loss, correct? No fluid loss at this time, just engagement. I changed the slave at the rebuild as I thought there was a leak, so hard to say.
Old 08-13-2012   #12
Lee,
Not necessarily especially if the slave is new. Is this a cast iron piece or the drawn steel? =Jeff= would be the real expert on this.
Old 08-13-2012   #13
yeah I had quite the ordeal with the slaves..
As Dominic asked, is it cast or drawn steel? is it a new part? If the seal is in backwards on the slave, if the car was parked nose Uphill, when you get in, push clutch and start car and it will NOT go into reverse it could be the reversed seal or a bad master.
If you pump it, does it get better?
Old 08-13-2012   #14
If I hit the clutch hard it shifts very smoothly
Old 08-13-2012   #15
it is NOT the cast version.....where can I get a quick replacement??
Old 08-13-2012   #16
Lee,
You could take it apart and reorient the seal. Again =Jeff= could guide you on that
Old 08-13-2012   #17
http://www.zfdoc.com/CHS_Actuator_Seal_Fault.htm
Old 08-13-2012   #18
is it a new part?
if not new, depending on the use if it seal was backwards the seal might be gone
Old 08-14-2012   #19
Lee,
The documentation for this on ZF Doc actually came from =Jeff= and his investigating the issue several years ago.
Old 08-14-2012   #20
Lee,
Yeah Bill B found it there and then I confirmed it on 3 more slaves
if you need a new Slave get it here:
http://powertorquesystems.com/index.htm
I got a new master and slave from him this year.. Jim is a GREAT guy to talk to and work with
