Old 08-03-2012   #11
Default Re: coil choice?
Originally Posted by sdycke View Post
Thanks for your suggestions! Once in a while this internet is good for something. besides poker. my bush league stress-test showed weak 1 and 6 sparks so....hello accel or d-e-l-c-Ohhhhhhhhhh. would anybody use a 'standard' coil....just asking!!!
Not Accels!!
Old 08-03-2012   #12
scottfab
scottfab's Avatar
Not Accels!!
Not MSDs. I had MSD in my 73 454. They're crap.
Accels now working fine for 12yrs in the LT5.
Scott
Old 08-03-2012   #13
I had an MSD 6a box on the 84 for 10 years.
Old 08-04-2012   #14
scottfab
scottfab's Avatar
I had the box on the 73 too. It worked great.
Coil didn't.
Scott
Old 08-04-2012   #15
sdycke
Funny you mentioned a mouse nest. First plenum pull revealed a terrific mouse....village? amusement park? definitely not just a nest. Had wierd dietary laws. Starter cable insulation and thats all. Asked about the standard cause I have one handy. but resisitance is 6 k ohms and originals are 5.3. Wonder if it would have made a difference. Oh well. will never know. Cheers!
sdycke is offline   Reply With Quote
Old 08-06-2012   #16
When I did my injectors I replaced the coils with new AC Delcos,the coil for 1-6 died at 8000 miles.I pulled them all out and replaced them with MSDs.
Old 08-08-2012   #17
jimmy b.
jimmy b.'s Avatar
Three years ago at Carlisle I had a slight miss only in 6th gear with a slight
load. When I got home I ohm check all the injectors and they were right on
specs. When I got to the coils I had a 5-8 coil dead. I got a new one from chevy but it didn't have the cyl numbers stamped on top but no big deal. Then
I thought if this coil went bad are the rest waiting till I put the plenum back on?
So then I thought if I change them all maybe I should put a better performance
coil so I went with the Accels.
They fit with a little bit of modification, you have to remove small plastic tabs
on each one so they sit next to each other again no big deal I used a hacksaw
blade only took a few seconds, took longer to find the hacksaw blade.
While I was doing the coils I decided to change those fancy ignition wires of
which I also ohmed and they were right on specs too but I replaced with a
new set from chevy without the logo printed on them. I cleaned and put the
original wires in the box for a later date.
I had about 28000 miles when the miss started and now I have almost 30000 and no problems but I didn't notice much of an improvement over the stock
coils, I just hope they last a long time. I'll see if I can post a few pics of the
coils, I'm just learning how to get pics up...jim
jimmy b. is offline   Reply With Quote
Old 08-08-2012   #18
Hammer
Hammer's Avatar
Talking Re: coil choice?
AC Delco is standard and they'll fire the 415's so they will be fine for yours.
Old 10-04-2012   #19
sdycke
Thanks for all your input. In the end I tried 4 new MSD 8224's from Smut Racing and for my trouble got 8 misfiring plugs. A new Delco coil to replace the bad 1/6 and putting the other good, original ones back got 8 happy sparklers which never seem to miss a beat. Go figure. Is there a lesson here? You decide.
Old 10-05-2012   #20
ghlkal
ghlkal's Avatar
FWIW, on Monday I ordered 4 Delco D545 coils from Amazon for $34.27 each. It was the least expensive I could find online. I'm looking at Amazon this evening and they show the coils for $45.07. I was hoping I could point folks to a good deal. Anyway, if you need parts, it doesn't hurt to see what Amazon is asking when you're ready to buy.
