07-11-2012 | #11 |
Re: Proper oil level help, please
My '90 was also very hard to get a good read, so don't feel bad....I generally checked as others have said after sitting overnight....It also used a bit more, than I have noticed with the '94. the '90s did not have valve guide seals, so I figured it was normal to burn off some......just another one of the racey '90 things.
2009 LS9 1990 LT-5/sold/Bought my Baby back 1994 Lingenfelter LT-5/sold 1973 LS4/sold |
07-14-2012 | #12 |
I believe most cars are calibrated to be read after about five minutes of engine off, such as checking on the road. I really depends on how Chevy intended it to be read. I think Porche is meant to be read while the engine is running. That way there is always the same amount of oil in suspention.
07-14-2012 | #13 | |
07-15-2012 | #14 | |
This is one of those instances when it would be wonderful if someone who attended the LT5 Gang Reunion in Stillwater last August could email one of the folks on the LT5 team and get the answer. John
[SIZE=1] AustinJohn in Austin, Texas '90 Black/Gray ZR-1 #1723[/SIZE] [SIZE=1] Ported intake, Haibeck Chip, CORSA exhaust, 4.10 rear end, Hurst shifter, drilled/slotted rotors, stainless brake lines, 32mm sway bar, 170º thermostat '94 Red/Gray Coupe[/SIZE] [SIZE=1] Stock '85 Black/Black Coupe[/SIZE] [SIZE=1] Anything but stock (Lingenfelter 383 and every Lingenfelter mod available in '88 including 3:54 rear end, big brakes, Centerforce clutch, MSD electronics and Borla exhaust.) True "barn find" restored/upgraded by me beginning in 2010.[/SIZE] |
07-15-2012 | #15 |
I feel confident that if I do a cold check first thing in the morning, I should have a very accurate reading to go by. Just my opinion.
1988 KOH Prototype EX5023 sold 1990 ZR-1 #444 Convertible 1990 ZR-1 Black #966 1991 ZR-1 Quazar Blue #296 1957 Duntov SS Project Last edited by Blue Flame Restorations; 07-15-2012 at 09:49 PM. |
07-15-2012 | #16 |
So wouldn't a good test be to do an oil change, put in exactly the right amount of oil, 8.8 quarts in my case, and then see where it falls on the dipstick. Sitting overnight is certainly going to give an accurate and consistant reading, but that all hinges on where GM put the full mark.
Just checked my owners manual. It says check the oil when the engine is cold, that means it sat for hours. Apparently Chevy wants all the oil in the pan to check it. |
07-15-2012 | #17 | |
07-15-2012 | #18 | |||
Simple, safe, good practice is to let it drain overnight, then refill with 9qts. Drive it, park it overnight, check the level in the morning & top it off, usually 0.2~0.5 qts.
07-16-2012 | #19 | |
