Old 07-01-2012   #11
efnfast
Default Re: Use HVAC display as tach
My 90 #1786 is in C.
Old 07-01-2012   #12
ghlkal
ghlkal's Avatar
Originally Posted by scottfab View Post
What is the Serial number of your 90?
#2180
The display wasn't showing a temp in F, it appeared to be about 1/2 the temp gauge reading. So it could be in C ...
Old 07-02-2012   #13
aafc
aafc's Avatar
my 1990 #2546 temp shows c
1990 white/black auto eq.
aafc is offline   Reply With Quote
Old 07-02-2012   #14
scottfab
scottfab's Avatar
I checked mine on #16.
It is indeed in C.
I was reading my notes wrong in the manual.
I placed an arrow into the table which is missing #16 and wrote
"16 is the water temp not in F". So much for my hand writing.
I missed the "not" when reading it.
Sorry for the confusion.
Scott
Old 07-04-2012   #15
scottfab
scottfab's Avatar
I am now wondering what other interesting diagnostics are available similar to the HVAC diagnostics?
There is a lot of diag stuff (on a 90 MY) via the ECM and displayed on the dash, both active and passive. As I remember this is not available on other MYs. I should say there is some there but not as much as on the 90.
Scott
Old 07-04-2012   #16
VetteMed
2. Since the parameter #16 digital readout is in deg C where deg F=((9/5)(deg C) +32) and the gauge is analogue can we assume the temperature data for the HVAC digital temperature reading is from the same sensor and exact (in other words like the tachometer we can calibrate the temperature gauge)?
The temp display is taken directly from the ECM, which gets its information not from the gauge sensor, but from the other sensor right next to it.
Old 07-05-2012   #17
VetteMed
Cliff, that's correct!
Old 04-20-2017   #18
Livin' in the 80's
Livin' in the 80's's Avatar
Do you know the locations of these two sensors are located?
Livin' in the 80's is offline   Reply With Quote
Old 04-20-2017   #19
Yes. They're both located on the drivers side IH, toward the front. The plenum has to be removed to access them.
Old 04-20-2017   #20
Gunny
Gunny's Avatar
doesn't seem to work on mine
George Jones
Founding Member #14
www.zrwon.com
