Old 06-22-2012   #11
Demps
Demps's Avatar
Default Re: I hope Im reading this right.
Here's my rear shock with Carter's mounting bracket.
Ted
Old 06-22-2012   #12
Daniel_Mc
Daniel_Mc's Avatar
Ted,
Very nice! That will save the hassle of the mounting in the rear frame. All that is needed is the opening for the actuator/top of the shock opened up correct? Something like this has been done on the bars on the white car. Much easier and no cutting on the frame in the front.
Daniel_Mc is offline   Reply With Quote
Old 06-22-2012   #13
Demps
Demps's Avatar
Daniel, correct. Carter helped a LOT and manufactured the rear & front relocation mounting brackets. Open up the rear shock motor frame hole to accomodate the shift and mill head of reversed lower multilink bolt.
Front
Old 06-22-2012   #14
Blue Flame Restorations
Ted
I have trhe same brackets on my car with Rippie coil-overs.
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 06-25-2012   #15
Daniel_Mc
Daniel_Mc's Avatar
rhipsher,
Here are the coilovers installed:
Front:
Must be slightly bent to accept the hat:
Old 06-25-2012   #16
Daniel_Mc
Daniel_Mc's Avatar
Rear:
This mounting area must be pushed forward about 1/2 an inch:
