#11 | |
![]() Join Date: Jan 2009
Seems like all is well now. Your text leads one to believe the fix will not work.
Scott ![]() Vett owner since 1979._It's about the car and the people Last edited by scottfab; 06-27-2012 at 11:36 PM. |
#12 |
![]() Join Date: Jun 2007
#13 |
Hi All,
I bought a working used Accelerometer that matched the numbers from the failed unit in the car. Based on the tips from all of you I thought the used replacement would work. It did !!!!! I installed the new switch, erased the codes, took it for a test drive (at 3 mph the ABS motor cycled). Got no trouble code light. Check the ABS system by grounding pin 11 and I got 12, 12, 12. I believe I am good to go at this time. I opened up the failed accelerometer and the weight moves but is binding up and not moving freely. I will play around with the unit and see if I can free it up. Thanks for all the help. Have a great summer Cheers Don ![]() ![]() |
#14 | |
Where it's binding etc.
#15 |
Hi Scott,
I will take a couple of pix of the accelerometer and post them for you and others to see what the unit looks like with the cover off. Thanks, Don ![]() |
