Old 06-08-2012   #11
scottfab
scottfab's Avatar
Default Re: Spark Plug wire jumps off?
This is likely to be a leaking O ring at that plug in the valve cover. If the problem occurs more ofter after a WOT then that's it.
Scott
Old 06-08-2012   #12
Pete
Pete's Avatar
Originally Posted by gbrtng View Post
Replace the spark plug - torque to 19 #-ft.
BINGO
Been there,drove me nuts trying to find the problem.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 06-08-2012   #13
RHanselman
RHanselman's Avatar
Originally Posted by Pete View Post
BINGO
Pete
I really dont think thats what drove you knuts Pete
Ron Hanselman
Founding Member #80
CM Lifetime Member #1093
1991 #383 Twin Turbo
1993 #099 Ruby, Jeal 368 w/Snake Skinner body
1961 White with Red Int
RHanselman is offline   Reply With Quote
Old 06-08-2012   #14
John Boothby
John Boothby's Avatar
This is just a "stab in the dark", and might be "out there", but it happens (or did to me): If the plug is loose, the boot might be getting forced out by chamber compression? Any sign of gas leaking around the plug??
P.
I was thinking this also.
John Boothby is offline   Reply With Quote
Old 06-08-2012   #15
USAFPILOT
USAFPILOT's Avatar
i don't see anything i squeezed it down a little...then it wouldn't go back on...so i opened it back up a bit and too loose, then squeezed an on tight...still pops out. Going to try the O-Ring thing next before new plug wires.
Old 06-09-2012   #16
Pete
Pete's Avatar
Before you do all that work changing wires and taking cam cover off.
Did you change the spark plug?
Been there done that,just trying to save you time and money.
New spark plug $2.00 and 30 seconds.
Pete
PS
Ron H. your right i've been nuts for a while LOL
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 06-09-2012   #17
scottfab
scottfab's Avatar
Pete
PS
I agree try spark plug first but don't replace. Move swap it with another cylinder. If the plug on that cylinder move out you have it. If it stays on the same cylinder you have it (O riing). If neither backs out the you had contamination in the threads.
Scott
