Old 06-05-2012   #11
zr1nsxgto
zr1nsxgto's Avatar
Default Re: Tire width
Thanks for the pictures. That makes it much easier to compare the different tread design and also a comparitive as to size. I think I'm sold on the Nitto 555's. Looks damn good to me.
zr1nsxgto is offline   Reply With Quote
Old 06-05-2012   #12
Pardon me. I was thinking of the 315 Nitto. I'll leave any of the technical subjects to you more experienced guy's.
Old 06-05-2012   #13
VetteMed
Frank, do you mean Sumitomo?
Old 06-05-2012   #14
Not even Andrew...............305's. I'll STHU now and go downstairs and enjoy a big bowl of crow !
Old 06-05-2012   #15
Demps
Demps's Avatar
Not tread width but inside of tape measure aligned with inside sidewall on each.
All 315s. Sorry I can't answer the Nitto 555 question.
BFG KDs
Nitto NT05
Goodyear GSCs
Ted
Old 06-05-2012   #16
VetteMed
Nitto 555 Extreme Performance, 315/35ZR17mounted on 11" a-mold:
Width of tread contact patch is about 11"
Entire cross section (sidewall to sidewall) is about 12"
Andrew
Old 06-05-2012   #17
GSJoe
There arent may tires to choose from in stock sizes. Michelin P/S makes a pretty good hooking 345 rear tire for us.
But ultimately for street and light strip duty there is a Michelin Pilot Super Sport (Viper) - 275/35-18 345/30-19
The Nitto 555's do hook up pretty good. While looking "funny" on the ZR1. And could turn out to be a real handful in the wet esp. if they are used on the early cars with no ABS.
What early cars without ABS are you referring to? My '90--and an early car at that--has ABS. Do you mean traction control?
GSJoe is offline   Reply With Quote
Old 06-05-2012   #18
VetteMed
Yep, probably meant ASR, not ABS. I think Frank forgot his brain pills this morning
Old 06-05-2012   #19
Kevin
Kevin's Avatar
how do the 555's handle? i'm only used to nitto as a drag tire maker
Old 06-05-2012   #20
VetteMed
Well, the only other tire I've had on my Z was the Sumitomos. Suffice it to say that the 555 deserves much better than to be compared to the Sumis. I've got about 6K miles on them now, seem to be wearing well, and grip seems good as well. I don't track the car, but I've had no issues with questionable grip like I did with the Sumitomos, which got a little scary on me a few times.
