#11 |
Thanks for that. Just out of curiosity, how do you know it has fresh motors, etc.?
#12 |
NOS = New Old Stock. Never used or installed.
#13 |
Thanks for the education.
#14 |
Update: I installed the NOS cooling fan shroud/fan assembly a few days ago.
The trick to doing so without having to open the AC system, is to unbolt the RH side fan from the shroud, and maneuver it out through the bottom. Then the shroud and LH side fan can be brought up through the top. My suspicion was correct -- the RH motor, which was the one that blew the fusible link, would only freewheel for about 1 to 1/2 revolutions when spun by hand. The LH motor, and the NOS motors, will spin for 7-8 revolutions before coming to a stop. Everything buttoned back up, I now have cooler A/C at idle and less risk of overheating in traffic. |
#15 | |
![]() Join Date: Nov 2007
In doing a little research on fusible links I read where the insulation of fusible links is designed to withstand the heat of the wire melting without melting itself and possibly catching fire. I replaced the link and the fan motor (with a new Bosch). I too took it out from the bottom. I was surprised at how easy a job it was. P. Last edited by Paul Workman; 07-14-2012 at 05:04 AM. |
#16 | |
![]() Join Date: May 2012
#17 | |
![]() Join Date: Aug 2006
However, there are generic fusible links available from multiple sources. If it were I, I would determine to gauge of the wire the fusible link is protecting and go 4 numbers higher replacement fusible link. "Typically, a given harness segment is protected by fusible link that is four gauge numbers smaller. A 14-gauge wire would be protected by an 18-gauge fusible link". |
