Old 06-03-2012   #11
carter200
carter200's Avatar
Default Re: Failed Emissions
Originally Posted by rhipsher View Post
Really. I'm kinda shocked by this. Is there any funny odor?
Rick, really? You of all people know about funny odors
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
ZR1NET Founding Mem #155
Old 06-04-2012   #12
pantera1683
You don't need to throw a bunch of money at this one. All you need to do is add a half gallon of denatured alcohol to half full tank of gas and take it for a few wide open throttle runs before taking it to the inspection station.
I have headers, bullet cats, and full B&B exhaust. I have a Haibeck performance chip but I always replace it with the stock chip before testing and my car barely passes...but it passes
pantera1683 is offline   Reply With Quote
Old 06-05-2012   #13
rhipsher
rhipsher's Avatar
You should smell me after eating Hobenaro chicken. Smells like propane. And burns twice.
Old 06-05-2012   #14
scottfab
scottfab's Avatar
Originally Posted by USAFPILOT View Post
What is it going to take to get in under the 821. What are the chances the guy was in the wrong gear?
Look at it this way. It could be worse.
You could be in Kalifornia.
Is the CAGS pulled in?
Scott
Old 06-08-2012   #15
USAFPILOT
USAFPILOT's Avatar
Denatured Alcohol lowered the Nox a lot...but raised my HC's to the point I failed the retest.
The tech tried a few different tricks with the machine and ran it again at higher RPM and I just barely passed on my 3rd try.
He said this time it was running too lean. He did the final test with only one tailpipe probed. Not sure if that was ok or not. Even still...the car has an x-pipe so both sides should read the same.
Anyway, I'm now good for another year!
Old 06-08-2012   #16
pantera1683
I'm curious, did you run it with the skip shift disabled? I'm pretty sure it will test better with it enabled and with the tech running the higher speed test in 4th gear.
Old 06-08-2012   #17
USAFPILOT
USAFPILOT's Avatar
low RPM is where my car is having issues...as the RPM's come up the HC's and Nox go down.
Old 06-08-2012   #18
scottfab
scottfab's Avatar
definitely works.
Scott
