05-30-2012 | #11 |
Re: Closed Loop/AC ON?
correct. at idle they will not be operating, so the only way they'd affect idle would be if leaking.
05-30-2012 | #12 |
However, the AC defaults to AUTO when you reconnect the battery.
05-30-2012 | #13 | ||
described here: http://www.zr1.net/forum/showthread....hlight=amperes My pump/pumps only drew about 5.5 amps should have been over 8. Either one is not working or is very weak. Both pumps are new and I have had this issue since before changing them. But I am thinking this area needs further investigation. Maybe a wire or relay problem. I will get to it next week and update if I find anything interesting. Thanks |
06-06-2012 | #14 | ||
is back to normal. It now shows 9.47 versus the 5.5 mentioned earlier. So I am back to square one. The car still starts and runs fine as long as I leave the AC off. As soon as I push the AC button the car will not idle and will not run unless I blip the throttle. Quote:
but smoothly (no binding) by hand. The only thing I know for certain that is wrong with the car from a mechanical perspective is that the secondary injectors are shot. I have been reluctant to spend the time and money to replace them because I felt certain they could not affect low rpm driveability. But I don't know what else to check. Unless someone comes up with something else to look at I guess I will be putting new Accels in the secondaries next. Regards |
06-06-2012 | #15 |
If your power key is still functional,leaving it "off" takes the secondary injectors offline, and therefore rules them out as a source of a driveability issue.
06-07-2012 | #16 |
My 91 had the same issue, Idled poorly with the a/c on. When the a/c clutch engaged it changed the idle 200-300 rpm. Stock injectors ohm 'ed out good and passed the leak down test. I changed them anyway. Now it idles great, no fluctuation in idle speed. I bet yours are leaking. Does it smell rich at Idle?
[I]4-cam[/I] [I]1991 ZR-1 Blk/Gry #31[/I] [I]SW Headers/Xpipe- Dynomax Muffs[/I] [I]Ported top end[/I] [I]Secondaries Removed[/I] Tune by Dominic |
06-07-2012 | #17 | ||
I would expect that as well. The power key has no effect on the problem whether on or off. I also cannot see where turning the AC on/off would effect driveability, and yet it does. Quote:
AC on does not just affect the idle a little bit. It ruins the idle. The car will not idle. It begins to run very rough and will shut down in less than 10 seconds unless I keep blipping the throttle or shut off the AC. I know the secondaries are no good so I will change them out just to eliminate any doubt that they are having an effect. Anyone know the Accel secondary injector part numbers? Thanks |
06-07-2012 | #18 | |
Same as the primary part number. 150821. You have to grind off the tab on the connector in order to use the Accels. Not sure if that's on the primary or secondary side though.
06-07-2012 | #19 |
Check/clean/replace your IAC.
Pete
06-09-2012 | #20 | |
http://www.amazon.com/gp/product/B00..._ya_os_product Good price I think. Will report back after install. Next week I hope. Regards |
