#11 | |
![]() Join Date: Nov 2007
Good point about the Castrol TWS 10W-60 (synthetic that you get from the BMW dealer) and change the trans fluid too, while yer there. (Already mentioned changing the clutch fluid - easy when the slave is outta there too!) P. |
#12 | |
![]() Join Date: Jan 2012
Wow, thanks for all the feedback, suggestions, and encouragement.
For my use, a stock spec clutch is fine. I found a Valeo kit on eBay - thoughts? I've read good things about the C frame plates. IIRC, it makes sense to try to open the tranny plugs while the tranny is still connected to drain and fill, right? I don't see any oil throught the inspection plate, so I assume my rear main is holding OK. Will the clutch housing drop down past the cats? I assume I just drop the exhaust past the cats. It looks "interesting" to reach the T50 bolts on top of the tranny. Should I invest in a better quality torx bit for those? I'm in Fredonia which is about 40 minutes north of Milwaukee (I'm between Milwaukee and Road America ![]() Quote:
#13 |
While the trans to bellhousing bolts do indeed have a torx pattern on them, a hex socket works fine on the outside of the bolts. I don't remember the size (15 or 16 mm perhaps), but I did not need to use a torx bit on them.
Definitely drain the oil before dropping the trans, otherwise it will all pour out the tailshaft as you lower it. Similarly, don't refill until it's back in position, bolted in. Andrew |
#14 |
![]() Join Date: Mar 2007
I bought a trans tailhousing plug from Autozone and it did not spill a drop...
#15 |
#16 |
![]() Join Date: Aug 2008
Pauls correct. You don't have to take the trans out from under the car. Just shove it to the back of the car. I pulled mine all the way out the first time because I wanted to clean it up.
#17 |
![]() Join Date: Jul 2005
IMHO, if you have less than 50K mi. on the car, you probably don't have to replace the pressure plate, only the disc.
But, if you do replace the whole assembly, make sure you get the correct year throw out bearing. They are incompatible. |
#18 |
Well, yes, the black tag (early) and blue tag (late) ZF used a different diameter input shaft sleeve, so the blue tag cars had a plastic sleeve pressed into the center of the release bearing. This plastic sleeve can be removed to make it usable in a black tag situation.
#19 |
OH!
Forgot to mention it before, but before you disconnect the drive shaft from the differential, mark the shaft and the yoke on the diff or you might reinstal it 180º from where it was, and likely cause vibration or "buzzing" at high(er) speed...Ain't dat right Lee? ![]() Remove the MAP and fuel pressure regulator from the back of the plenum, or you might pinch them between the plenum and the firewall when tilting the motor to pull the trans. Good time to clean up the grounds too, since they're right there and easy to get to once the bell housing is off. No time like the present to change to an aluminum FW too, but I digress... And, another thing not mentioned yet: A bottle jack is needed along with the floor jack. You use it to support the engine when pulling the trans and reinstalling it too, and when aligning the C-beam after wards (before the bolts are tightened at either end) the tail of the trans (via the C-beam reference) needs to be approx 1" from the side of the beam to the tunnel, and approx 1-3/4" from the "roof", ± 1/4". ![]() Hmmm.... Do I sense someone about to write up a checklist for the Registry newsletter??? HMMMMM???? ![]() P. |
#20 |
Keep these great tips coming!
![]() Now, will the clutch housing drop down past the cats? I assume I just drop the exhaust past the cats (I don't want to pull the exhaust manifolds too) |
