Old 06-07-2012   #11
Default Re: Computer fans in inner fender.
Im wondering how these fans hold up to moisture. Computer fans are not known for being all weather or sealed for that matter. I too would like to see this setup if possible, GC
Old 06-10-2012   #12
Merlot566jka
Bilge blowers will survive.
What's the purpose of these?
Merlot566jka is offline   Reply With Quote
Old 06-11-2012   #13
Tyler Townsley
Low speed in town traffic cooling. Also I have mine so they stay on after turning tne engine off to reduce heat soak isues under the hood.
Tyler
Old 06-11-2012   #14
Paul in VA
Hi Tyler: Any pics available yet?
Paul in VA is offline   Reply With Quote
Old 06-11-2012   #15
Tyler Townsley
Ask and sometimes you get:
I used a aftermarket fan controller and thermostat sensor and mounted them in the drivers side lightwell. I glued the sensor to the radiator frame with silicone rtv. (I used this method on an earlier car.)
I used a harness with an adjustable pot so I could hook it up hot and control the fans after turning off the ignition. The harness I used can control 2 fans so I used one ckt for one side the second for the other side.
I used 3 inch fans from radio shack, a 3 1/4 inch hole saw.(I
tried a 80mm fan and it is too large.
Drilled 3 holes
used a automtive plastic repair glue. You can use bolts or glue but you have to grind the ears off one side of the fan.
Labels are in wheel well.
Glued up.
Tyler
Old 06-11-2012   #16
Tyler I fixed your post for you so the pics would show. I have added the last one here with your text as only six pics are allowed per post. GC
A lousy picture of the drivers side using one 80 mm fan.
The fans are 33 cf per min so 90 cfm each side when done.
Its an attemp to provide some kind of flow through the engine compartment when in slow traffic.
Old 06-11-2012   #17
Tyler Townsley
[QUOTE=GOLDCYLON;143153]Tyler I fixed your post for you so the pics would show. I have added the last one here with your text as only six pics are allowed per post. GC QUOTE]
Thanks, I missed the 6 per post. I clicked on the pictures after I posted and they showed up.
Tyler
Old 06-12-2012   #18
Paul in VA
Very cool (pun intended)! Thanks Tyler!
