Old 05-13-2012   #11
Default Re: Is you Knock sensor taking performance down for the count?
never saw one on the 92 when it was off..
Old 05-13-2012   #12
VetteMed
Originally Posted by gbmidyear66 View Post
I'm confused... I had understood (incorrectly?) that the LT5 does a self test of the knock sensor / circuitry at start up. If the seonsor is inoperative - presumably it will indicate a DTC?
Yes, this should trigger a code 43.
Old 05-13-2012   #13
scottfab
scottfab's Avatar
This is almost true but not quite. Yes the ECM will do a test of the ESC module once after start but these two conditions must also be present:
1. Eng temp above 194deg F.
2. at or near WOT (high load)
So, based on this circuit description it is entirely possible to not get a code 43 when the sensor is unplugged.
Scott
Old 05-14-2012   #14
gbmidyear66
Thanks for clarifying the fine print Scott
So..... if you drive like a granny (I can assume LGAFF does not qualify on this count), OR you've changed your thermostat and/or fan cut-in - you won't get a DTC?
I dunno - I have early activation of my fans and I still see temps > 200. Sounds like I need to disconnect the sensor and see what happens.
[SIGPIC][/SIGPIC]
1990 Corvette ZR-1 #2824
4.10's, Custom PROM, Flowmaster, Top End Port
NCRS BC Chapter
gbmidyear66 is offline   Reply With Quote
Old 05-14-2012   #15
scottfab
scottfab's Avatar
I also have early "fan on" but don't see temps north of 200 on short drives so in my case I'd not see a 43 (if sensor or ESC were defective) on every drive.
I can tell you that yesterday I hit WOT at above 200 several times on the way back from Home Depot because I chose to go to the one that is a few miles farther away than the one nearest me. I did this ostensibly to test to see if I'd get a 43 but also as an excuse to feel the WOT and to save some $ by shopping in a "no sales tax" US state
Scott
Old 07-15-2013   #16
Vettetech1
Bring up this thread again. Got a 92 zr1 here has a code 43. Suspecting a knock sensor issue. OHMed the sensor and it is at 3.891k. Customers car not sure of full repair history on it. Know all primary and Secondary injectors have been replaced over the past 3 years, and the fuel regulator was replaced last year. Just don't seem to have the power it should. Any suggestions would be helpful as i don't see to many of these.
Vettetech1 is offline   Reply With Quote
Old 07-15-2013   #17
Is your ASR light or other lights coming on? I had a crack in the board of my chip for the knock sensor
Old 07-15-2013   #18
Pete
Pete's Avatar
Did you or somebody replace knock sensor?
You might have a 1990 knock sensor.
I will check and get back to you later.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 07-16-2013   #19
Have a read on this thread for some additional explanation. It's not a matter of knock, it's a matter of the knock sensor circuitry being operational. You don't get a MALF code if knock is occurring.
http://www.thirdgen.org/techboard/di...de-43-esc.html
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 07-16-2013   #20
Vettetech1
I did see the service ASR light come on yesterday, but it isnt on now. The service ride control light will go on and off while driving but it did that last year also. This all started as a feeling of a miss in power mode when you get on it. I checked the injectors and had 2 secondary injectors at 8 ohms the rest were 12.6. I replaced the 2 bad ones and suggested we replace the other 2 secondaries that were OE. So over the past 3 years all 16 injectors have been replaced. The car was running like it should fast and strong, it then sat for 2 weeks till the owner came, when he picked up the car he said it was running rough and thought maybe it just needed to be driven. Now it acts like its missing on hard accel in both power and non power modes. Like injectors are messed up again. I put my solus pro on it and found a 43. hit up google and found you guys. cleared the code and havent seen it back on yet but haven drove it either. Can feel the miss or stumble just goosing it in the bay.
