#11 |
![]() Join Date: Jul 2004
Okay here's a follow up.
Got some safety wire but couldn't find the spinning wire tool anywhere so when I tried to install it I couldn't get it to tighten properly with the confined space. I also tried forming a replacement shape from the safety wire thinking that might be close enough to work, unfortunately it's not 'springy' enough. Then I noticed a set of old hubcovers, with a spring wire 'lock' on the inside. Whipped one off, cut it up a bit and then had 20 mins of bending, shaping flattening etc. I now have a good 'Heath Robinson' facsimile that has some spring and looks good till I can get a replacement. ![]() By the way it was a '98 Aurora hubcover. Thanks for all the suggestions Dave
1991 #1516 Black/Black davidmkelly.com Author of fast-paced, sci-fi thrillers. |
#12 |
![]() Join Date: Feb 2006
Red Green strikes again ...
#13 |
I had to look up "Red Green" but yep, sounds pretty close
