04-24-2012 | #11 |
Re: SYS light flashing.
I believe it is the TRIP REST button that cycles through the codes.
I'd have to go and try it to be sure. Can't right now.
04-24-2012 | #12 |
Once I get into the system mode I tried pushing several of the buttons,one at a time of course and couldn't pull up a code or the --- never changed except to revert back to 4.1 or back to 4.7.
04-24-2012 | #13 |
Some of what I need to type here is in the manual. Some is not. It's stuff I discovered.
Like for instance if you use menu 1.4 you can cause cycle through many active diag mode that turns one thing on at a time like: oil change light, and all other dash lights, or door alarm bell, or (and be careful of this) the horn which just scared the crap out of me. Anyway I made myself a little box that shorts out any two pins (not just the normal two) Not sure if that was in the manual. The menus are 1.1, 1.4, 1.7, 4.0, 4.1, 4.4, 4.7, 7.0, 7.1, 7.7, and others. 4.1 is the ECM codes. ( I think the 4.7 one resets it) 1.1 is the CCM codes. I am typing all this from memory so do check it against the manual. The page is 8D-8 according to what I wrote on my diag box. Do you have a manual?
04-25-2012 | #14 | |
04-29-2012 | #15 |
Finally got something,H13 which translate to left 02 sensor.Ive gone through the diagnostic process a bunch of times and while it doesn't always go through the process the stored code of 13 always comes back.
04-29-2012 | #16 | |||
Shorting specific pins to enter just that module allows focus on that module only and to reset the codes while there.. Quote:
04-29-2012 | #17 | |||
04-29-2012 | #18 | |
04-29-2012 | #19 |
Here's figure 3 on that page with the pinout diagram.
