Old 04-17-2012   #11
mike100
Default Re: THIS SEEMS TO BE GOING AROUND!
Originally Posted by oricale View Post
Allright...shouldnt the IAC disconnected make the engine react???...when I unplug mine, nothing changes....(and its new)
if you unplug it while it is 100% closed- it will just stay closed, won't it?
a scan tool will tell you its position with iac count values. zero is maxxed out- blocking the port completely.
Old 04-17-2012   #12
oricale
Allright so I checked the cruise...no change
I plugged the airhorn and the engine stalled so I dont think I have a vacuum leak.
still surging!
[B][I][COLOR=red]1990 ZR1[/COLOR][COLOR=black] [U]#00077 [COLOR=red]RED[/COLOR]/[COLOR=red]RED[/COLOR] (10Y022 PEP CAR)
[/U][/COLOR][/I][/B][B][I][COLOR=red]1991 ZR1[/COLOR][COLOR=black] [U]#00517 ("Irene")[COLOR=red]WHITE[/COLOR]/[COLOR=red]RED-SOLD:cry:[/COLOR] [B][/B]
[/U][/COLOR][/I][/B][B][I][COLOR=red]1992 ZR1[/COLOR][COLOR=black] [U]#00445("The Revenant")[COLOR=red][COLOR="Black"]BLACK [/COLOR][/COLOR]/[COLOR=red]RED(2016 T.O.D!) [/COLOR] [/U][/COLOR][/I][/B]
[B][I][COLOR=red]2009 [COLOR=red]Z06!![COLOR=black]BLK/BLK rare Linen interior[/COLOR] 707HP!![/COLOR] [/COLOR][/I][/B]
[B][I][COLOR=red]2006[/COLOR] BLK/BLK Z51 (Just SICK FAST!)SOLD)[/I][/B]
[B][I]1996 BLK/BLK LT4 Grnsprt(sold...Twice!)[/I][/B]
[B][I]1991 RED/REDL98(Fell off the shipping truck:([/I][/B]
[B][I]1980 BLK/RED L82(Sold)[/I][/B]
[B][I][B][I]1990[/I][/B] RED/BLK(sold.....In Japan)[/I][/B]
[I][COLOR=black][B][I]2006[/I][/B][/COLOR][/I] [COLOR=red]Mustang GT[/COLOR] ([B][I]mach 1[/I][/B])[B](sold)[/B]
[COLOR=black][B][I]1969[/I][/B][/COLOR] [COLOR=red]Mach[/COLOR] [B][I]1(sold in Japan)[/I][/B]
[COLOR=black][B][I]1969[/I][/B][/COLOR] [COLOR=red]Mach[/COLOR] [B][I]1#2(sold)[/I][/B]
[B][I]WAZOO Member...[/I][/B]
[url]www.evolution-motorsport.com[/url]
facebook/evolutionmotorsportengineering
Your Local [url]www.Amsoil.com[/url] dealer/user..
*Victory Loves Preparation*
oricale is offline   Reply With Quote
Old 04-17-2012   #13
phrogs
phrogs's Avatar
I have that same pedal feel in my car at times usually low mph and just trying to push a little more and it feels like its stuck and then bam your hitting the gas hard. I have a ported throttle body as well.
JOHNNY P
Currently own
Old 04-17-2012   #14
secondchance
Originally Posted by USAFPILOT View Post
I have a plug wire that keeps backing off the plug causing a miss every now and then.
Just in case, check and make sure the spark plug is still torqued correct. I had a pulg boot that kept popping off and turned out to be a cylinder leak caused by a loose plug.
Old 04-17-2012   #15
oricale
ALTHOUGH !! I did get a 22 code this time..its the TPS sensor voltage under .24 volts at one point BUT....I have checked it and it is at .55!
Old 04-17-2012   #16
mike100
if you have a bad tps pot or a loose connection, I'm sure that is playing havoc with the control loop in the ECM idle strategy.
Old 04-18-2012   #17
If you unplugged the IAC and it was already at 0 steps, it won't make any difference. So the IAC is not controlling idle suggesting that there is enough air(too much actually) coming through the TB. If you don't have a leak, could be the Min Air or the throttle blades.
BTW, unplugging the IAC will require you to do the IAC reset procedure.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 04-18-2012   #18
oricale
How does one do that?
