Go Back   ZR-1 Net Registry Forums > Club Regional Areas > Mid-Atlantic Region
Old 04-09-2012   #11
QB93Z
QB93Z's Avatar
Default Re: WAZOO - WMD - 8 April 2012
It was a great WAZOO day!!
Here is Jim helping Yun clean the valley with a pot of boiling water:
(Don't tell my wife that her pans are being used to clean an engine.)
The ground problem on Paul's 1991 ZR-1 was the connection on the rear of the engine, on the right side. The bolt is very close to the bolts that hold the bell housing to the block. We suspect that the bolt was loosened accidently during bell housing removal two months ago.
Old 04-09-2012   #12
Originally Posted by Scrrem View Post
So????? How did things go?
Rich
Rich
Wow the windshield trim and weatherstrip look new! Thanks for taking care of the trim and SPECIAL THANKS to Yun for his expertise on the install
Looks "as new"
Old 04-09-2012   #13
Scrrem
Scrrem's Avatar
Originally Posted by ZZZZZR1 View Post
Rich
Looks "as new"
Cool, glad your happy with the trim, can't wait to see it on Sat!! Like I said, I thought yours came out better than mine!!
Rich
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
Old 04-09-2012   #14
SteelBlueZR1
A BIG thank you goes to Jim Voter for solving my battery drain no start problem, which ironically started the morning of Wazoo maintenance day. He masterfully identified the electrical short caused by the stereo power wire as the cause in 1 minute.
On the way home, I enjoyed an intense 110 mph spring breeze, as I upshifted to fourth. With Dave's gentle prodding, I am slowly, after 8 months of ownership, learning to drive the crap out of my 6k mile ZR1 and not worry about miles or something breaking.
Bert Rankin
1991 ZR1 Steel Blue / Steel Blue
#1029
Haibeck chip, slotted rotors, camber brace, C-beam plates, OBX exhaust, Nitto NT555 tires
[SIGPIC][/SIGPIC]
Old 04-09-2012   #15
Paul in VA
YEA TEAM WAZOO! I am very happy! Yes, one little bolt caused all the issues. Unbelievable! Thanks to everyone, especially Jim!
Thanks ... Paul
(Paul in VA)
Paul in VA is offline   Reply With Quote
Old 04-09-2012   #16
Y-me
Why are these events always happen when i have a 24hr shift at my Firehouse?
I looked at Pauls car and could see the ground but it looked ok, but with no lift and hot car forget it.
Y-me is offline   Reply With Quote
Old 04-09-2012   #17
Excellent. Enjoy!!!!!
"drive it like you stole it"
Old 04-09-2012   #18
SteelBlueZR1
Hey, I forgot to thank Dave for the oil change help and encouragement. I switched to 10-30 Mobil1 hi Mileage as Mark Haibeck recommends this oil which meets 1100 ppm Zinc needs and is easy to find.
Old 04-15-2012   #19
JThomas
JThomas's Avatar
110 mph runs, 7000 rpm fifth gear blasts. I'm starting to see a re-ocurring theme here.
Joe Thomas
Corvette Club of Michigan
NCRS-Michigan Chapter Member
NCM Master Ambassador
Former NCM Board Member
1991 ZR-1 Melon Copper Metallic/Black
1992 ZR-1 Bright Red/Black (Sold)
1995 ZR-1 Bright Aqua/Gray (Sold)
2012 ZR1 Super Sonic Blue / Dark Titanium
JThomas is offline   Reply With Quote
