03-26-2012 | #11 | |
Re: tuning gurus
MAP v RPM cells as possible. Finally, I might notice some things about a tune a novice would not while driving. That isn't available remotely. Even if the motor is stock, each motor will have its own characteristics. As an example a stock motor w different gears or aluminum flywheel has a different optimal tune. When you tune your own, close isn't good enough.
03-27-2012 | #12 |
Re: tuning gurus
So is it safe to say that the ostrich is the way to go?
Do you know if we need a certain socket?
1990 ZR1 #2574 Medium Quasar Blue Metallic 1 of 19 Last edited by 1990 quasar blue; 03-27-2012 at 01:18 PM. |
03-27-2012 | #13 |
Re: tuning gurus
You need to use piggyback board onto stock prom for Ostrich.
03-27-2012 | #14 |
Re: tuning gurus
Thanks again. I appreciate your time.
1990 ZR1 #2574 Medium Quasar Blue Metallic 1 of 19 |
