Old 03-16-2012   #11
bdw18_123
Default Re: Needing help with TP Switch
Good call on the no-pierce methods, guys!
I didn't even think of that when I did mine and I usually do think of things like that.
Old 03-16-2012   #12
Originally Posted by mike100 View Post
I keep a couple of paper clips and safety pins in the tool box because, if careful, you can slip them under the rubber GM weatherpack wire seal and touch the metal terminal. then use a clip lead to attach the pin to the meter leads...hands free at that point.
This is how I did it the first time,takes a little patients but it works.
Old 03-16-2012   #13
VetteMed
I am assuming this TPS adjustment applies to a 90', 91', and ???
Yes; applies to most GM EFI systems.
Old 03-16-2012   #14
Route 66
Route 66's Avatar
Thanks again. are you sure about the .54 volts DC ?
Route 66 is offline   Reply With Quote
Old 03-16-2012   #15
mike100
pretty much for most of the 90's GM stuff. when I had my vacuum leaks, the first thing I checked was the TPS setup and it was factory set at .54 or .55 volts. I would set it to that level- should be right after that.
Old 03-16-2012   #16
Route 66
Route 66's Avatar
I will do that.
Thank you...E
Old 03-16-2012   #17
Route 66
Route 66's Avatar
I got the TPS set back where it should be an it no longer has a falt code for the TPS ! Thanks to all of you for your input.....E
