#11 | |
#12 | |
![]() Join Date: Nov 2005
#13 |
![]() Join Date: Mar 2004
Knocking or pinging ?
One range colder than stock is good for a car that is stock or some top end mods. Red Line injector cleaner may help out a bit. |
#14 | |
#15 |
Nothing wrong with getting the most out of your car. I was thinking about a Haibeck chip but I don't think I want to do it until after I change out my existing OEM injectors first $$$$. I replaced a bad primary injector last May and the next time one goes I'm doing all 16.
#16 | |
#17 |
![]() Join Date: Dec 2004
I think that the idle speed "hang" in neutral @ coast down is a program that reduces exhaust emissions upon de-accleration. Back in the old days, around the early 70's, some cars had de-accel valves. I know my 72 V6 Capri had one. It did the same thing that my 90 Z does when you coast down from speed in neutral to a stop, I'm that old too!
![]() It seems that the program will not let the motor return to idle speed instantly but rather the idle speed seems to come down in two steps & takes a few seconds to get back to 6-700 rpms as I coast down to a stop in neutral in my Z. I even notice that if I coast down to a stop in gear it seems like I loose my compression breaking for brief periods & then it's there & then it's not & then it's there again. I figured that since my ECM was not setting any codes that this must be part of the emissions program?? I don't know enough about EEC motors to say for sure but mine does this all the time and it's passed emissions testing two yrs on a dyno here in NYS so I just figured that it is "normal". I would think it prevents a rich condition during closed throtle de-accleration??? I know that's what the idea of the "de-accel" valve was in my Capri, rich emissions prevention @ de-accleration.
#18 |
Sounds like a reasonable explanation to me. Knowing that this happens to at least 1 other Z takes it off my mental check list. Thanks.
#19 |
![]() Join Date: Sep 2005
Hello gentlemen yes it has been awhile since I have been on the form, I finally got situated in the new position at work and boy I thought I had problems with the car. Well I managed to find the time to install the new RC injectors and a set of the plenum power plates and the car runs fine. It was so nice to fire it up again. We made a few dyno pulls on Monday and the new prom works great up to 6900 R.P.M. making 370 H.P. to the ground but then the air/fuel reading went from 13.5 down to 11.5 from there to 7200. The horse power reading didn't fall off, so I have to send the prom back to Aaron at S.G. Corvettes for some final tuning. This is a bit of a pain not having a tuner that can do all this stuff with in a reasonable driving distance. Oh well we will play the FedEx game back and forth for a few times again until we get it right.
Haber rj |
#20 |
Haber rj, those are some nice numbers! Glad to hear your Z is back to it's old self. RC sells some nice parts. Also glad to hear that the job is a good fit.
![]() ![]() Tom
