03-25-2013 | #11 |
Re: Winter Porting Project Done!
Congratz on your successful mods and renovation! But the best is yet to come! At those mods you should be putting down 50-60 more ponies!
P.
03-25-2013 | #12 |
I did the same to mine this past winter: plenum, injector housings, water pipes, throttle body, and air horn in light silver with black lettering. Had a few issues with the throttle body but along with the injector change it runs great! I also changed O2 sensors a month later and it really runs sweet now!
03-26-2013 | #13 |
Lee - were you looking for the color code for the powdercoat I chose? It was...
SK544MIRROR SILVER SPARKLE (SINGLE STAGE) (Powder by the Pound) OK, that was last year's project..... I have shamefully ignored the beast most of this winter (I have kids that consume most of my spare time) - but have gotten busy the past few weeeks. - Re-did rear brake system (new braided SS lines, slotted zinc coated rotors, Hawk pads) - Noticed the clutch resevoir near empty - finally installed the new slave cylinder that's been sitting on my workbench for a year - Now I am fighting a "simple job" of changing the oil. Taking the easy way out allways catches up with me..... I went to "Mr Lube" last year and had them change my oil. Well the drain plug is now damaged and WAY overtight. No luck with a bolt extractor, no luck with vice grips. I'm now letting it sit with penetrating oil on it. If that doesn't help - what I am left with? - drilling it out?
[SIGPIC][/SIGPIC] __________________ 1990 Corvette ZR-1 #2824 4.10's, Custom PROM, Flowmaster, Top End Port NCRS BC Chapter |
03-26-2013 | #14 |
Paul - you are close....
I went from 354 RWHP (baseline with flowmaster exhaust) to 392 RWHP +38 RWHP from Lees top end port. From what I observe - it does not seem that I have left much on the table for the RWHP I am getting for the mods I have done? I am guessing the next cheapest/easiest thing to do is headers....
03-26-2013 | #15 |
Those are good numbers. Corey just finished mine today and it did 430 whp WITH headers. Looks like you're already there.
03-26-2013 | #16 | |
Quite a bit o science involved to optimize (any) motor's performance, e.g., runner length and diameter, various angles, tapers, etc. And, in lieu of that - serendipity works too many times! It is starting to look like there is a well established route to 500-510 chp on a stock bottom and stock cammed LT5. And, it can be done in stages as time or $$ permits; the biggest chunk being fully porting the heads. Anywayz...your results and mine were comparable, at that point except yours had the TB ported, and mine was not. But, I semi-ported the heads by tapering the inlet from 36mm down to the stock diameter at a point just shy of the valve guides. It crosses my mind that porting the TB might be about equal to semi porting the heads instead. (Course, BOTH would be ideal methinks: even on a top end project. Hmmmm.... sez me.) PRIMARY PORT SECONDARY PORT The result was to change the personality of the car...as you well know! Anyway...(just rambling here) I'm contemplating porting the TB now as the last piece of the porting "recipe", and it will be interesting to see what porting the TB is worth on a dyno. So, your results - sans headers and full head porting - are very incouraging! P.
03-26-2013 | #17 | |
1990 ZR1 #2574 Medium Quasar Blue Metallic 1 of 19 |
03-27-2013 | #18 | |
Has anyone done any "testing" of ported TB's?
03-27-2013 | #19 |
Do you mean porting the air horn or installing larger throttle blades in the the TB?
My 92 has the 63mm TB, not sure there is alot to gain I ported the air horn on this job to create somewhat of a venturi ....did the same on the one I just did..... Mercury tested all of these items one upgrade at a time and recorded them all, one of the line managers has all the data at his home
LGAFF 90 #966-150K miles-sold 92 #234-sold 1987 Callaway TT #17 1991 ZR-1 #1359 Last edited by LGAFF; 03-27-2013 at 12:20 AM. |
03-27-2013 | #20 |
Isn't the stock TB 58mm?
