Old 02-26-2012   #11
Default Re: Blower running at 1 speed
Originally Posted by chriskinzel View Post
OK. This little problem is kicking my a**. I just replaced the blower motor. Now it seems to move a little more air, but it still runs at only 1 speed! Anyone have any other ideas? This shouldn't be as hard as it is. Thanks.
Well this sucks. You already replaced the blower controller resistor next to the motor correct? That being the case either the head unit or the programmer above the accelerator is the culprit. Before you buy any more parts I suggest using your red factory service manual fault trees. Then with some codes we can see what is really going on. GC
Old 02-26-2012   #12
chriskinzel
chriskinzel's Avatar
Yea, I guess I will need the book sooner or later so I will get one on order. Thanks to all who tried to help. This really is a good group of people. Chris
chriskinzel is offline   Reply With Quote
Old 02-26-2012   #13
Let us know if you figure it out so you can close the post and help the next member out. FSMs are a great investment to keep your car running.
Old 03-01-2012   #14
gbrtng
gbrtng's Avatar
Looking at section 8 of the FSM I see that the CCM is also connected to the programmer. You'll have to back-probe some of the interconnect wires to see where the fault originates. At least it's a hard fault - everything I get hit with are intermittents - but my guess is the programmer.
Old 03-01-2012   #15
RHanselman
RHanselman's Avatar
I have a 96 C4 parts car there in Farmington at Corvette Recycling. You can try both parts and then buy the one you need....
Ron Hanselman
Founding Member #80
CM Lifetime Member #1093
1991 #383 Twin Turbo
1993 #099 Ruby, Jeal 368 w/Snake Skinner body
1961 White with Red Int
RHanselman is offline   Reply With Quote
Old 03-03-2012   #16
chriskinzel
That sounds like my best option. PM me and I will make arrangement on getting parts!
You guys are the best
Old 03-03-2012   #17
Nice of you Ron! Not sure if the programmer will work however I think the head unit is the same. GC
Old 03-04-2012   #18
RHanselman
RHanselman's Avatar
Sent...
Ron Hanselman
Founding Member #80
