#11 |
![]() Join Date: Oct 2011
Are stock chip available these days?
#12 |
![]() Join Date: Aug 2009
You can find them on Ebay or on here running ~$200 to $400. When they come up....
Did you check the code on your chip?
1990 ZR-1 #642 |
#13 |
Not yet, traveling this week. When I unhook the cables to drop the box should I have the battery disconnected?
#14 |
![]() Join Date: Feb 2009
There's one out there now...here's the link.
http://www.ebay.com/itm/1990-LT5-Cor...item5648666654 Rich
#15 |
Unhook the cables?It take about 2 minutes to gain access to the chip.Disconnect the battery,remove the 2 10MM nuts on the left side of the ECM,lift the ECM out of the bracket,flip the ECM over and you will see 4 7MM bolts holding a small panel in place.The battery is the only thing you need to disconnect.
#16 |
Will do when I return to Texas.
Thanls |
