Old 01-30-2012   #11
rhipsher
rhipsher's Avatar
Default Re: Risk of ignoring lifter noise?
My buddy bought one of those Ford 1super ton King Ranch super duty pickups Brand new. $55k 6 months later he couldn't afford the payments anymore. I knew that was coming. Lol!
Old 01-30-2012   #12
VetteMed
Originally Posted by rhipsher View Post
My buddy bought one of those Ford 1super ton King Ranch super duty pickups Brand new. $55k 6pickup months later he couldn't afford the payments anymore. I knew that was coming. Lol!
Yep, that's a lotta green for the new trucks. Too rich for my blood...
Old 01-31-2012   #13
You have no secondaries right? blades removed etc? Mine did this before the blades broke apart and hit the pistons
Another option according to Lee since your on a budget on a hi miler anyway
http://www.zr1.net/forum/showthread.php?t=16532
Old 01-31-2012   #14
VetteMed
Another option according to Lee snce your on a budget on a hi miler anyway
Correct, no secondaries. I thought at first that this noise was coming from one of the accessories, but I don't think that's the case now.
Thanks for the reminder on that option for lifters- however, I'd suspect that a lifter that is collapsed or otherwise damaged in a way other than wear on the surface that contacts the cam lobes, it's better to just replace it.
Old 01-31-2012   #15
VetteMed
Hmm, looks like they offer true rebuilding services, not just refinishing the surface. Good to know.
Old 01-31-2012   #16
Concur I would just buy Thier cores already done
Any pieces missing out of the balancer? this will cause a knocking as well is the motor shaking as well? Or just noise under the plenum or cam covers. Can you post up a video ?
Old 01-31-2012   #17
Correct on the cheap as well.
Old 01-31-2012   #18
VetteMed
I haven't noticed any pieces missing from the balancer - I will inspect tomorrow to be sure. The motor is pretty smooth overall, but at times does have a little shake to it.
Old 01-31-2012   #19
sammy
just a thought ,but do a fuel pressure test and see if it holds. i know you put in new ones but sometimes they do go bad or leak .
Old 01-31-2012   #20
Pete
Pete's Avatar
I have a question did the noise start after you installed new injectors.
Another question did you buy the injectors from FIC?
You say it varies with temps?
I like to start from cheap to expensive.
I would check spark plugs new or not,i had a brand new spark plug drove me nuts trying to find the noise.
Check coils,wires.
Then move to lifters.
If you know which bank the lifter noise is on i would change all the lifters with new lifters on that bank price is not so bad $15-$20 each X 16 lifters,what i would do in your position is pin the cams like the FSM or post when you get that far and we'll help.
Not such a bad job just go slow and take your time,just make sure it's lifters.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
