01-23-2012 | #11 |
Re: An option for spare tire replacement....
this is why i have aaa
01-23-2012 | #12 |
Yeah, I have it too... but, I like to be prepared for the unexpected.
01-24-2012 | #13 | |
Thanks, Craig
01-24-2012 | #14 |
VetteMed,
Please send me an additional info also. Is the sealant refillable after use? Or is this for one time use only? |
01-24-2012 | #15 |
Same idea... ContiComfortKit by Continental and is a system that many Euro GT cars come with (I have for my C6 since I have non run flat tires)>>>
Michael :cheers: [I][SIZE="2"]1990 RED on RED #566[/SIZE][/I] [I][SIZE="2"]WAZOO MEMBER[/I][/SIZE] |
01-24-2012 | #16 | |
Thanks. Please share what you might have heard or your experience. When I was going to order the Conticomfortkit, Tire Rack said it would not work for our OEM size tire or my 335/30/18 on the other wheels I have.
01-24-2012 | #17 | |
Here is a link to the ContiComfortKit tire application range>> http://www.conticomfortkit.co.uk/htm...Ktyretable.pdf Knock on wood, I have had no experience actually using the Conti system but have heard from others that it works as advertised
01-24-2012 | #18 | |
01-24-2012 | #19 | |
Personally, after looking at our sensors I don't see how the stuff can get in. The plastic case is fairly tight, and since the out rush of air from a puncture would drag the sealant to it. I just don't see a big chance of fouling our sensors.
01-24-2012 | #20 | |
The sealant cylinder is replaceable on its own from GM, but is not refillable as far as I can tell. The compressor can be used without the sealant cylinder -- the instructions state to fill the flat with sealant and air, then drive a few miles, and then recheck pressure and inflate as needed. I haven't investigated a PN for a replacement sealant cylinder, but I can do so when I get a chance. -Andrew
