Old 01-13-2012   #11
Pete
Pete's Avatar
Default Re: Dreaded Fuel Pump Failure (I think...)
Pretty sure this is it.
1996 2500 Chevy Suburban 7.4L and 1995 Corvette LT1 use same pump.
If you look up 1995 ZR-1 it shows the pumps AC Delco #19180770 X 2
http://rockauto.com/catalog/raframecatalog.php
As you know you will need 2 of them.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 01-13-2012   #12
Or if you want to do the Bosch pumps: Bosch P/N 69225 these require making a relief slice in that plastic holder for the pump body, actually two cuts as these pumps are just a smidge fatter than the stock LT5 pumps. They work great though.
http://www.rockauto.com/catalog/raframecatalog.php this the RockAuto listing.
Sorry the rock auto site seems to have a thing against a direct link. Just log on, press button for the catalog, click "parts search", then fill in the P/N, Brand name of mfg, type of part, and click find.
Old 01-13-2012   #13
RHanselman
RHanselman's Avatar
Wasn't there someone selling a remake of the entire unit? I thought I heard grumblings of that last year...
Cheers,
RH
Ron Hanselman
Founding Member #80
CM Lifetime Member #1093
1991 #383 Twin Turbo
1993 #099 Ruby, Jeal 368 w/Snake Skinner body
1961 White with Red Int
RHanselman is offline   Reply With Quote
Old 01-13-2012   #14
Cheers,
RH
That was the partsladi formally on Ebay. They no longer exist
Old 01-13-2012   #15
and the pumps that came with that set up were not very good. One Brother had a failure in less than a month and I had a failure in less than 6k miles! We both bought the Bosch pumps. I have to give credit for the research to the other Brother as he found the swap with the Bosch pumps.
The only thing I am leery about is that when I bought mine two yrs ago they were $90.00 each....I don't know what to say about the price being lowered now. I don't even recall for 100% sure where the Bosch pumps that I bought back then were made....china? or Mexico? or IDK. Sorry Ron!
Old 01-13-2012   #16
Pete
Pete's Avatar
The 69225 is for same year suburban with 5.7L
The 69226 is for the 7.4L suburban and LT1 corvette.
If the 69225 fits better and plug is same maybe thats the way to go.
Pete
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 01-13-2012   #17
Hib Halverson
Zip Products sells the "remake" of the OE, LT5, pump assembly. Actually, it's more of an update rather than a remake as the Zip pump assmebly includes some modern technology in certain places.
I have a Zip pump assy in my 95. It's been there for about a year and about 5500 miles. It has worked flawlessly.
The PN is GT-406.
I stored my OE pump assy as a spare but...any of the OE pump assys still in service are a minium of 16 years old...beyond the pump's design life, I would think. Earlier in the thread someone pointed out that if the car has seen a lot of operation with low fuel levels, ie: below 1/4-tank, pump life can be shortened because they run hot. Also, if the car has spend any length of time more than a year not running, sometimes that causes a decrease in pump life due to gasoline turning to "varnish".
Hib Halverson
Technical Writer
former owner 95 VIN 0140
current owner 19 VIN 1878
Old 01-13-2012   #18
RHanselman
RHanselman's Avatar
Thanks for the help...
I bought a pump and swapped it out this afternoon. She runs great! Man she has some torque for a N/A car.
Cheers,
RH
Ron Hanselman
Founding Member #80
Old 01-13-2012   #19
VetteMed
The Bosch turbine pumps were made in Brazil, when I did the swap a while back. Here's the post where I described the procedure:
http://www.zr1.net/forum/showthread....osch+fuel+pump
Andrew
Old 01-13-2012   #20
RHanselman
RHanselman's Avatar
Andrew
Thanks Andrew... If the one I bought fails I'll upgrade to your version
Ron Hanselman
Founding Member #80
