Old 01-07-2012   #11
flyin ryan
flyin ryan's Avatar
Default Re: 441 cid dyno results
Originally Posted by Pete View Post
Nice Kevin.
Now those are some real numbers and backs it with ET/MPH.
Ya', nice job...
Old 01-07-2012   #12
Corbusa
wow!! , Great results.. This has to be on my to do list ( getting a 441 ) ..
Old 01-07-2012   #13
For easier viewing...
IMMMMMMMpressive!!
Excluding inertia and drivetrain losses, that would put it comfortably north of 660 hp at the crank...an enviable figure for any NA, street driven Corvette!
I couldn't help but notice, there is quite a bump in torque between the two runs - or so it seems ( a little hard to see the graph), resulting in a pretty good lift in HP across the spectrum. Can you shed some light on what made the difference in the runs? Were they done on the same day, or is one an overlay from a previous test?
P.
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 01-07-2012   #14
ALZR1
Paul the torque/HP difference between the two runs is the cool down time I would think.
Wow Kevin very impressive out of An automatic N/A Z.
Good Job Pete,you know those 247 are starting to look really good.
AL.
ALZR1 is offline   Reply With Quote
Old 01-07-2012   #15
Nice Kevin . And with an automatic too !
Frank Urbo.
NCM Lifetime member # 982
Registry Founding # 237
Old 01-07-2012   #16
AL.
Al,
I'm assuming the 247 is the intake cam duration?
Old 01-07-2012   #17
ALZR1
Al,
Yes Sir.
Back to Kevin good job.
AL.
Old 01-07-2012   #18
Pete
Pete's Avatar
Al,
Thanks Al
For the non believers exhaust cams are basicly Stage I.
This car starts and drives like grandmas Oldsmobile
Kevin drives this car to and from work 30 miles each way in traffic.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 01-07-2012   #19
Thanks Al
Pete
In support of your post, or more correctly, your point that a big inch LT5 making huge power does NOT suffer for street manners and low end torque or drivability...Excellent job, Pete.
See link
P.
90 #1202
Sans secondaries
Old 01-07-2012   #20
Thanks Al
Pete
Pete,
I think we have gotten a number of data points lately that suggest exhaust isn't the issue. In fact, on a stock block, intake cam may not be the constraint. We've got some pretty good numbers for stock cam stock displacement motors putting out between 430-450rwhp. I had a converstaion with FU at BG and he stated that the LT-5 was actually overcammed. I'm beginning to believe that's pretty accurate. The motor appears to have been "throttled" from the factory. Just look at the performance bump you get by simply porting the top end. This baby just needs to breathe more.
