#11 |
![]() Join Date: Feb 2009
OK Shek, you sold me. I think I'm doing this to mine before they go off for refinishing.
Rich
#12 |
![]() Join Date: Sep 2010
#13 |
Are these 1/8" SS plugs sold at HD/Lowes, typically? Got the plenum off now, and I'd like to finally put an end to messing with the cooling system every time...
Andrew |
#14 | |
http://www.summitracing.com/parts/SUM-G1485R/ Rich
#15 |
Thanks for the link, Rich!
#16 | ||
We order often from McMaster Carr here at the shop and I just threw my order in with another job. http://www.mcmaster.com/#stainless-steel-hex-socket-pipe-fitting-plugs/=g1o3x9 Quote:
#17 |
OK, great. What is the correct size drill bit and tap to use?
Thanks!! |
#18 |
#19 |
Thanks, Shrek!
Andrew |
