Old 01-03-2012   #11
VetteMed
Default Re: Cleaning out a radiator
You might have some difficulty keeping oil cooler in place w/o AC condensor. This is because oil cooler is hung onto AC condensor and the condensor is held in place by the bottom and top shroud.
Correct, but it is doable, I think. The condenser I'm running right now, is an ACDelco unit, but didn't have the proper holes drilled to allow for hanging the oil cooler, so I installed them as 2 separate units. Granted, I still have the condenser in place, but having them mounted together isn't 100% required. The rubber spacers in the top and bottom of the stack, have circular cutouts for the placement of the tips of the end tanks of the oil cooler.
Old 01-03-2012   #12
secondchance
Originally Posted by Scrrem View Post
Hey Yun, do you happen to have a pic of the cuts you made? When I do my top end this month, I am also installing a Ron Davis radiator, would like to make getting the shroud off as easy as possible in the furture.
Rich
Let me know when you start the project. Now thatI look at it, it may not be necessary to do what I did.
Old 01-03-2012   #13
Scrrem
Scrrem's Avatar
Wow Yun, that a lot of cutting. Yeah, I'm pretty anal about how things look, I may have to do it the hard way. I'll let you know when I start, hopefully it will be later this month.
Rich
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
Old 02-11-2012   #14
Scrrem
Scrrem's Avatar
Well, got my radiator pulled today and found why I was overheating in traffic......Wow!!
Rich
Ron Davis Radiator
Old 02-11-2012   #15
VetteMed
Is that your radiator, or the lint screen from your dryer?
