Old 05-09-2005   #11
Z Factor
Z Factor's Avatar
Default
Originally Posted by 240Z TwinTurbo
I believe SGC has plans to copy the kit and make it available through an install at his shop. It is too much work to sell as a kit and have someone install themselves.
BTW, new numbers on the car today.
565hp/532ft-lbs@wheels with 7.5psi of boost.
Any clue as to a price range yet?
Old 05-10-2005   #12
240Z TwinTurbo
Default
Please contact SGC for pricing.
229-226-4447
240Z TwinTurbo is offline   Reply With Quote
Old 05-10-2005   #13
Z Factor
Z Factor's Avatar
Default
229-226-4447
I'll check with Aaron, but it will be more out of curiosity than any realistic chance I would buy the set up. Other than a few reversible mods, I'm going to keep my 1990 stock.
Thanks for all the info on the project. You and everyone involved deserve a hand. =D>
Old 05-23-2005   #14
supercowboy
Default
Is this done with the stock compression? Was The head gasket replaced with a thicker one?
supercowboy is offline   Reply With Quote
Old 05-24-2005   #15
Default
After reading this all I can say is holy cow!! That is almost doubling the out put of a LT5!!! to all the guru's of HP! Amazing results.
It makes me wonder what our motors would have been like in the newer chassis. That would be a sweet ZR-1 with all the advances in technology the C5's & C6's have. Tom
Old 05-24-2005   #16
Z Factor
Z Factor's Avatar
Default
I don't know the answer to your question, but wanted to welcome you to the forum.
Hopefully 240ZTT will be back to let you know.
Old 05-24-2005   #17
Z Factor
Z Factor's Avatar
Default
Well I would not want the giant rear end or Barbie looks of a C-5, and I'm still undecided about the C-6's integrated headlights. However, I see you point.
Old 05-24-2005   #18
Default
Hi Z Factor, I agree with you! I wasn't thinking of the body stlye although I should have said that. I actually had a picture in my mind of my 90 Z body sitting on a C5 or C6 chassis' technicial achievments. Sorry, my apologies to the stylists at corvette. I mean no disrespect to 5's & 6's, but I like my Z's boby style just fine.
Although those cars have the only fat a$#'s I've seen that I could like!
May I say this? Oh heck I'll say it..."Hail the King! Long live the King!"
I'm sorry my Z is new to me! Tom
Old 05-24-2005   #19
bigd
bigd's Avatar
Default
[Is this done with the stock compression? Was The head gasket replaced with a thicker one?]
Supercowboy, The Stage I turbo was done with stock comp. (11.0:1) and hg's just like yours and mine. I believe the only mods to the car prior to the turbos was p&p intake, headers & B&B exhaust. Then they finished the test by adding an Xpipe. Stage II will involve lowering the compression. I will be seeing Aaron next week and verify this info.
Don
bigd is offline   Reply With Quote
Old 05-24-2005   #20
supercowboy
Default
Don
I believe they would remove the headers for some type of manifolds is my guess there.
Here are a couple of questions that I have;
Did they use bigger injectors?, What system are they useing to tune it with?, Are they using an fmu or not?, How many pounds of boost was this with? What kind of turbos are they useing?
