Old 12-29-2011   #11
Default Re: master debate
Okay I just dug out the caps. What you ordered and received was the correct part. You just ordered the wrong part! I'm not trying to be funny either. The early M/C dual reservoir type caps come in two components. The hard center part with the writing, and the outer soft seal part. Let me know which it is that you need as I have both the outer soft seal and the complete caps from my original M/C.
Old 01-04-2012   #12
sdycke
Thank you for your help Tom! Now that you explained it, its so obvious. It was the hard cap I needed (and had). I guess someone had laid a heat gun or a soldering iron on it and messed it all up. Better now. But all the time /frustration when the fix took 15 seconds. I feel pretty sheepish. better go hug the wife.
sdycke is offline   Reply With Quote
