Old 12-05-2011   #11
pantera1683
Default Re: X-Brace
Man, that's awesome!!!
pantera1683 is offline   Reply With Quote
Old 12-08-2011   #12
RICKYRJ1
RICKYRJ1's Avatar
Default Re: X-Brace
I have a new GM X-brace never installed yet. I was thinking of boxing it out also to make it stronger. What is the conventional wisdom? is it worth it? I only paid $100.00 for it. No! I'm not going to polish it!
Old 12-08-2011   #13
batchman
Default Re: X-Brace
I've been thinking of one of these - since I race with rules I can only use the GM one and not RD. Would love a picture of yours, have wondered if it would clear my headers. Keep me in mind if you want to sell it, I think for non-rules use the RD one sounds a lot better.
Best,
- Jeff
[/I]
Old 12-08-2011   #14
Pete
Pete's Avatar
Default Re: X-Brace
I get a lot of pros and cons on the R-D brace it works great for flex but loose some ground clearance.
I have installed a 4 point roll bar and it really helped the back half of the car
now the front takes the blunt of all the bumbs and too much movement this is why i wanted to know if the X-brace helps,i need to do something for the front end.
I will let you know how well it works as soon as i try it.
I would love to make my Z ride like a C5/6.
The look of a C4 to me will never get outdated.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 12-08-2011   #15
Kevin
Kevin's Avatar
Default Re: X-Brace
does the "harness bar" or whatever they call it do anything or is it a waste? i'm talking about the one that mounts behind the seats and comes with a camera mount?
Old 12-08-2011   #16
a1991zr1
Default Re: X-Brace
i love my harness bar
[B]"the winner ain't the one with the fastest car its the one who refuses to lose"
- Dale Earnhardt
:saluting:
a1991zr1 is offline   Reply With Quote
Old 12-08-2011   #17
Polo-1
Default Re: X-Brace
"The Jack Test"
Without the R-D brace, you can only pickup 2 wheels off the ground. The frame flexes too much to lift 3 wheels off. ( 94 ZR-1 with harness bar installed)
With the R-D on, lifting the car at the jacking point it will pull 3 wheels off the ground.
FYI My C6 Z06 pulls 3 wheels off the ground using jacking points. So, If I lift at the front ( under outside mirror ) 2 fronts and 1 rear are off the ground. The same thing happens at the rear lift point ( 2 rears and 1 front ).
Old 12-08-2011   #18
Default Re: X-Brace
ran out of lift on my jack:
Old 12-08-2011   #19
pantera1683
Default Re: X-Brace
Pete
Pete,
Sounds like you need the RD Camber Brace not the Cross Frame.
Old 12-08-2011   #20
Kevin
Kevin's Avatar
Default Re: X-Brace
that's just from the harness bar?
