Old 09-28-2011   #11
a1991zr1
Default Re: how do you clear
disconnected battery for 30 minutes no luck now what
a1991zr1 is offline   Reply With Quote
Old 09-28-2011   #12
mike100
look behind the driver's seat to find the controller (in the storage bin w the abs stuff). Inspect the plug and cabling. Maybe re-seat it.
other than that, you need to consult the factory manual and get somebody who knows how to use an oscilloscope of logic probe (or even a multi-meter with a freq counter) to verify the presense of the VSS signal.
you might be able to do a little up front, quick and dirty parts swapping if you can borrow a known good fx3 controller from somebody else (or swap yours into a known good car).
Are you sure you have the shock actuator installed correctly and they all work? no codes for those?
Old 09-28-2011   #13
Kevin
Kevin's Avatar
https://corvettetroubleshooting.com/...eshooting.aspx
