Old 08-10-2011   #11
Default Re: Shift light and stealth mounting recommendations?
Here ya go :
http://cgi.ebay.com/ebaymotors/Rapto...item1c1144415e
Old 08-10-2011   #12
Daniel_Mc
Daniel_Mc's Avatar
I used the Harlan shift light in the A/C vent and it works great. Looking at around 50 or so.
http://www.harlan-engineering.com/st...hiftlight.html
Daniel
Daniel_Mc is offline   Reply With Quote
Old 08-10-2011   #13
Nacho_ZR1
Originally Posted by FU2 View Post
Done. "Carlos, your payment of US $110.95 has been processed by PayPal"
Now, any tips on getting the A/C vent off? Do I have to take apart the whole console or will a simple screw driver be all that I need...
Nacho_ZR1 is offline   Reply With Quote
Old 08-10-2011   #14
Phllips screw driver and the vent pulls out.
Old 08-10-2011   #15
Nacho_ZR1
Now thats something I can handle
Old 08-10-2011   #16
Coupe89
http://www.hashmarks.com/ShiftLight/index.html
1990 ZR-1 #642
Coupe89 is offline   Reply With Quote
Old 08-10-2011   #17
Nacho_ZR1
Old 08-11-2011   #18
HAWAIIZR-1's Avatar
This is the shift light I bought and installed; it works like a champ and very easy following the instructions here.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
Old 08-11-2011   #19
I used a wire from a coat hanger to" fiche" behind the kick panned to the connector on the firewall (above and to the left of where the drivers left ankle would normally be - tying into the tack signal wire. The Raptor sits behind the A/C vent. Very stealthy...until it comes on. No trouble seeing it then!
P.
Old 08-11-2011   #20
P.
Paul,
It would be easier and more convenient to just use diag harness connector on drivers side and pull switched power and tach signal from there. Add a ground to the MAP sensor bolts then snake wires between A pillar and IP pad.
