08-06-2011 | #11 | |
Re: Help!
If you want to do something creative tonight I'd do the CCM codes maybe. It takes very little time and you will most likely find VATS errors if there are any involved. Instructions here: http://tech.corvettecentral.com/2011...trouble-codes/ |
08-06-2011 | #12 |
Re: Help!
did you check the fuses for the pumps?
1994 ZR-1 # 0102...SOLD |
08-06-2011 | #13 | |
Re: Help!
I recommend too that you install a Battery Tender to the battery to keep it in top shape at all times, regardless of temperature or time between use. And, the battery will thank you as well! (My wife's battery in her 69 C3 is going on 6 years now and it still cranks her 350/350 like new!) I have found the little 800mA unit to be perfectly adequate for battery maintenance. P.
08-06-2011 | #14 |
Re: Help!
Okay I set my VOM to read DCA and connected the red lead on the pos side of the battery and the black lead to the pump test lead and I got zero. could I have a faulty fuel pump relay? Okay my local guys dont have bosch pumps available but the to have the equivalent in Airtex E3270 will these be okay??
08-06-2011 | #15 |
Re: Help!
I have also remove the passenger side kick panel and looked there and on the side panel in near the hing FP1 and FP2 fuse are fine
08-06-2011 | #16 |
Re: Help!
Okay do I need to test my relay if so any ideas
08-06-2011 | #17 |
Re: Help!
Alright I have removed my gas door and rubber drain pan below the gas door. now what color wire do I need to run my test light to to see If I am getting power? or what color wire do I need to run power to?
Dave |
08-06-2011 | #18 | |
Re: Help!
I just changed the primary on mine this week, used a delphi, can get the number if you want it.
[FONT=Comic Sans MS][COLOR=red]"I wanna go fast!!"[/COLOR][/FONT] [FONT=Comic Sans MS][COLOR=#ff0000]-- Ricky Bobby[/COLOR][/FONT] |
08-06-2011 | #19 |
Re: Help!
Okay I have jump ground to the black wire going into the tank with the fuel pump four pin connector disconnected I then made positive contact with the green/white tracer wire and gray wire with my positive source. I didn't get anything out of either pump. I take it my pumps are bad? anybody have any comments??
David |
08-06-2011 | #20 |
Re: Help!
Something must be wrong here. What are the odds of both pumps being out??
