Old 08-04-2011   #11
HAWAIIZR-1's Avatar
Default Re: Thermal and Acoustic Insulation
Originally Posted by lakemeadzmonster View Post
search for item #400191413330 (8) left $129.99 plus 10.00 shipping email give me a personal email and I will give you the phone number. It's a store they have other C4 body parts.
That looks pretty good for under carpet insulation, but I think Yun is looking for exterior to block the heat and sound from the outside as well. I wish I knew about this one as I used a different product on the inside that was not as much material and custom cut as well. Thanks for sharing this.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
Old 08-05-2011   #12
secondchance
I found an alternate product and will give it a try. Exterior install is what makes it tricky since header heat could negate the adhesive. I will keep an eye on it.
Eitherway, deletion of cats and jet coating, I believe, actually will reduce the amount of heat in the hump area. If I see these pads losing adhesion I will just yank the off.
