Old 07-20-2011   #11
carmine
Default Re: newbie injector question
Just Purchased A Set From RCGreat People Discount For Zr-1 Members Carmine 90 Black Gray#357
carmine is offline   Reply With Quote
Old 07-20-2011   #12
Mike1952
thanks for the advice everyone.....now to study up on the plenum removal.
Mike
Mike1952 is offline   Reply With Quote
Old 07-20-2011   #13
Kevin
Kevin's Avatar
Mike
plenum is easy, it's the housings and injectors that are a little more difficult
Old 07-20-2011   #14
Mike1952
thanks for the warning....I think.
Old 07-20-2011   #15
Kevin
Kevin's Avatar
none of it is impossible, it's not even that hard just time consuming and intricate. the plenum is easy, the IH's are just a little harder
Old 07-21-2011   #16
scottfab
scottfab's Avatar
The last time I saw a thread on injectors it seems to me the RC design won out based on them being less prone to fouling (rotory design not pental) and that they were stainless steal (corrosion resistant).
I converted to RCs back in the 90s. (I think).
No problems since.
Things to note. The early Zs had a different diameter injector for primary and secondary.
Secondary injectors tend to leave the O-ring behind when you pull them out. The primaries don't. Be careful to note where the orange rubber seal goes when you pull the injector electrical connector off. It's tinny and rectangular.
They can dangle and fall off.
Good luck
Scott
Old 07-24-2011   #17
Kevin
Kevin's Avatar
whats the part number for the fic injectors we need? D042H-8 or D052H-8? is it the same for the primary and secondaries or not?
Old 07-24-2011   #18
ittlfly
You might want to view this, thanks to Jerry's Gaskets. click on: "click here to down load".
http://jerrysgaskets.com/store2/root...roducts_id=446
ittlfly is offline   Reply With Quote
Old 07-28-2011   #19
NWPzr1
I'm a newbie myself. I just ordered 16 rebuilt FIC injectors for a customers 1990 zr1. They said nothing about the primary or secondaries being different, and now I'm hoping they're sending me the right ones! I've heard nothing but good things about their customer service and honoring warranties etc etc... fuelinjectorconnection.com
I've seen others have good experience with them, anyone know if this is something to worry about?
Thanks
NWPzr1 is offline   Reply With Quote
Old 07-28-2011   #20
http://www.fuelinjectorconnection.co...&productId=208
These are the ones I would use if I were going to buy FIC injectors for my 90. I perhaps would give thought to the rebuilt FIC's if I wanted to save 1/2 the cash.
