#11 |
![]() Join Date: Jan 2006
Email sent!!
#12 |
Email sent
#13 |
![]() Join Date: Dec 2003
Update on Lodging: The room block code is "LT5 Reunion". Simply tell the desk The code when you call to make your reservations.
Jerry Downey JERRYS LT5 GASKETS & PARTS http://www.jerrysgaskets.com 1994 ZR-1, Black/Black, Lingenfelter Aerobody, 416cu in, 3.91 gears, coil-over susp, Brembo brakes, etc. 2016 Black-Red, 3LT-Z51 Auto 8-speed. Last edited by A26B; 07-15-2011 at 11:02 PM. |
#14 |
Make your reservations NOW as the block hold on the rooms will expire in one week, on the 22nd.
Please let me know by email if you are going to attend so I can keep you informed directly by return email.
#15 |
Roy Midgley has just confirmed attendance!! Roy was the GM Small Block Chief Engineer. Thanks Roy!!
#16 |
Although there is no registration requirement, please email me to let me know if you are coming and if you are bringing anyone with you. I do need to know to make sure we have space available at the places we are going to be having dinner, social hour, etc.
email me: jerry@jerrysgaskets.com
#17 |
![]() Join Date: May 2008
Email and PM sent. Got to learn to read before I type.
#18 |
This is an opportunity of a lifetime. I am serously considering attending. I will have to check with the wife and see if this is possible. I will have a decision in the next couple of days.
#19 |
Getting close. Be sure to make your reservations at the Holiday Inn while the block rate is still in effect.
#20 |
![]() Join Date: Feb 2006
Meanmyz reporting for duty sir! Email sent.
