Old 06-22-2011   #11
Alberta_ZR1
Default Re: Strange electrical problem..possibly
Originally Posted by gbrtng View Post
That's your problem - dump the kill switch and get a $20 float charger at WallyWorld instead. Don't know if they are available in Canada, but take a look. Maker is Schumaker, 1.5 amp
Good to know. I never had one of these on a car before. The previous owner had installed it and used it over the winter months. Maybe I'll pull that off tonight and see if my problem returns.
Alberta_ZR1 is offline   Reply With Quote
Old 06-24-2011   #12
Any updates, same thing happened to me today
Old 06-24-2011   #13
Alberta_ZR1
I removed the quick disconnect from the negative battery post and everything appears to be working fine now. I came down to Montana today (750km) and not a single glitch.
So I'm thinking that was the problem in my case...at least I hope so.
Old 06-24-2011   #14
I think mine is battery or Alt.....volts were going up and down fast, then once it warmed up, problem went away.
Old 06-26-2011   #15
Any flickering in the dash between the orange illumination glowand black leds? Mine did that before the Alternator crapped out. GC
Old 06-26-2011   #16
yes, just as you described, I think its toast.....
Got the message on the clutch....
Old 06-26-2011   #17
ittlfly
Same exact symptoms just before one of the diods in the alt took a dump. After having it rebuilt, all is well.
ittlfly is offline   Reply With Quote
