Old 06-18-2011   #11
Default Re: power key problem
After getting fixed I highly suggest bypassing at the PROM this will end the problem forever
Old 06-18-2011   #12
PhillipsLT5
PhillipsLT5's Avatar
Get Marc's chip, will overide switch
Old 06-18-2011   #13
Kevin
Kevin's Avatar
already have a chip from marc. I don't know if the 90 can use the chip to over ride the key. and even if it can, i'd rather fix the problem then just work around it
Old 06-19-2011   #14
I don't think you can override the 90 in the Chip.. good luck on the fix
Old 06-19-2011   #15
Kevin
Kevin's Avatar
thanks, it seems pretty simple. I talked to a friend today who gave me some ideas on how to attack this. i'm not sure when I'm going to dig into it but it should soon. i'll try and post pictures but when i get started that's usually the last thing on my mind. I think i have a weekend of zr-1 work coming up soon. the DS lumbar adjustment doesn't work but that's easy, I need to swap out the rear calipers, but that's not all that hard either and then the power key. I'm kinda looking forward to it
Old 06-19-2011   #16
Either that, or because leaving the switch in FULL POWER eliminates the need for a firmware "fix", it has just never been addressed in favor or higher priorities?
The BYPASS option: More than just a "work around" for some...
Primarily if (like me) your 90 is running sans secondary throttle plates. I'm just sayin if for any reason one has the switch removed anyway, shunting it would make a lot of sense - more than a cobble
P.
Old 06-19-2011   #17
Kevin
Kevin's Avatar
if i had the money to get my car ported, i'd have the secondaries dumped at the same time
Old 06-19-2011   #18
John Boothby
John Boothby's Avatar
I am the only one who drives my Z and the Power Key stays in FULL POWER.
Regarding the VATS key, mine gets dirty from time to time and won't start the car. I carry some alcohol wipes in the car and they work great for cleaning the contact on the key. Works everytime!
John Boothby is offline   Reply With Quote
Old 06-19-2011   #19
Aurora40
Aurora40's Avatar
Did you say what year car you have? The 1990 is extremely easy to fix the switch yourself. It's completely mechanical and very simple. Take the switch out, take the sleeve/cover off of it, and you will see how it operates. You can bend the internals slightly so that they make good contact again when rotated.
There's no reason to bypass or disable the switch functionality on the '90. It is simple to fix.
Old 06-19-2011   #20
Yep, that is what I did
