Old 06-30-2011   #11
DaveK
Default Re: Performace Regrinds
Excuse my ignorance on this. I thought the cams and heads were a matched package? How can they be exchanged?
Thanks
Dave
1991 #1516 Black/Black
davidmkelly.com
"Speed is often confused with insight." - Johan Cruijff
Old 06-30-2011   #12
Thanks
Dave
Cam covers and heads are a matched package for the bearing surfaces
Cams can be replaced just like a SBC Chevy, you can reuse cam bearings yet swap cams
Old 06-30-2011   #13
DaveK
Thanks for the explanation - obviously I didn't know that. That makes sense of a few things I've seen for sale and thought "how can they do that?"
davidmkelly.com
Old 11-23-2011   #14
pantera1683
Are these still available? Would they be good for a big cube motor?
pantera1683 is offline   Reply With Quote
Old 11-23-2011   #15
Originally Posted by Paul in VA View Post
Hi:
I recently drove the Blue Turtle and Jim's new Lingenfelter 368 Black Z (through WAZOO), both AWESOME but both different from each other. I really like the sounds of both cars and they are way faster than stock. Not trying to pester you but again... May I ask: What are the effects of the various sizes of the cams to the power curve? Do these raise the effective red line? If so, what other mods are needed to match the cams?
Paul,
Dave J and myself have the same cam specs as what Lgaff is providing. I've documented the dyno results of this ported top end/heads/cam combination
over stock cams and heads. Go to this thread:
http://www.zr1.net/forum/showpost.ph...1&postcount=96
You're looking at 30rwhp. The curve profiles remain the same, just more area under the curve.
