Old 05-29-2011   #11
Default Re: Cabin noise.
Thats not noise its music to my ears!
Old 05-29-2011   #12
mike100
Originally Posted by Kevin View Post
normally I don't but if mark writes it, i'm gona believe it
Well, he never gave out any empirical data, but just mentions that the Corsa makes 'better power'. This is kind of the same conclusion I had when I discovered the smaller pipe gave better and more consistent 0-60 acceleration.
I can't comment on the B&B resonator restriction because I had the x-pipe
the 3" B&B w/ X-pipe most definitely supports more HP than a 2.5" Corsa, but it is really a tad overkill because it hurts the mid-range punch a little on fairly stock engines. Could be worth 8 to 10 hp on a 400-420 hp LT5.
My conclusion after sampling both exhausts is that B&B is made well, but Corsa is well engineered.
Old 05-29-2011   #13
Kevin
Kevin's Avatar
he goes into some depth if you download http://www.zr1specialist.com/HAT%20W...%20Systems.pdf
Old 05-29-2011   #14
cvette98pacecar
90db for more than 2 hours can cause permanent hearing damage. Now I dont think anyone want to drive their car wearing ear plugs and noise cancelling head phones.
