#11 | |
Rich no really a lot of folks dont let these go without the entire engine, so they are still a tuff find. My Spare I paid almost $400 for just in case
#12 |
![]() Join Date: May 2008
#13 |
If I remember it was in the $700 region?
#14 |
![]() ![]() Join Date: Feb 2010
I will have a unit made that will function as new for a lot less. I'm not really concerned if I sell many of them. That's not why I am having them made. I need a couple and I'm a tight azz at heart.
#15 |
You would think that GM in their infinite wisdom would have seen fit to make a few extra of these items.
By the sounds of it there were only a handful of extra ones ever produced. Makes you wonder, exactly how many were made? TomC 'Crabs |
#16 |
Local rod builder has a mid year with a LT5 he is building. No thermostat housing. Made a plate to hold a small thermostat for each water neck, looks like it should work.
#17 |
![]() Join Date: Dec 2003
If he doesn't have the bypass system, he may "balloon" the radiator under high rpm conditions.
#18 | |
Yep. Thats what I was thinking the original thermostat looks like a jarvic heart for just that reason.
#19 |
That's funny!
#20 |
I plan to machine a block of aluminum for the inner area and the pathways for the flow. The small outlet will be tapped/threaded and the pipes will be welded. The upper housing will be of an alumium GM piece that I will choose from an in-stock item. This won't be that hard, really, the more I look at it.
