#11 |
![]() Join Date: Feb 2006
Aftermarket seal is not exactly like the factory part - I would try to fill between the gasket and the interior trim strip with some weatherstrip from Ace Hardware thick enough to push the gasket out a bit. Kinda caveman, but if the factory parts are gone, might be the best you can do.
#12 |
After playing with the adjustments and perfecting the horizontal and vertical alignment of the glass with the A&B pillar and roof, I was able to seal up the window after some improvising.
Due to the non-OEM weather-stripping that was used, I needed to elevate the weather-stripping so the glass would contact it correctly when the door was shut. After using the idea that was mentioned, I focused my attention on how I was going to elevate the weather-stripping without making it look like a patch job. So I went and picked up some super soft marine weather-stripping, removed the b-pillar stripping, and then placed a thin strip to the left of the b-pillar weather-stripping channel. After re-installing the b-pillar stripping, the extra strip I had installed caused the b-pillar stripping to sit slightly elevated within its channel. I can now shut a $20 anywhere along the stripping and there is significant resistance to remove it. The best part is that you can't tell that there is an added piece of stripping behind the b-pillar stripping. I know it's probably not the most ideal repair for some, but with the limited availability of OEM products, you have to make do with that works sometimes, right? I hope my repair makes sense and thanks for the help on here with this issue. T |
