Old 05-05-2011   #11
Thumbs up Re: Hood struts are missing
Originally Posted by carter200 View Post
Just order mine. Thanks for the tip
No sweat Carter. Thats what this Forum is all about. Helping one another. GC
Old 05-05-2011   #12
carter200
carter200's Avatar
Default Re: Hood struts are missing
You got that right
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
ZR1NET Founding Mem #155
Old 05-05-2011   #13
Rodder
I replaced my gas strut with a new one, # 609-623, from MAD few years ago. Lifting the hood the first inches off the locks is not heavier than any other car and from about half way it will spring up by it self. There is no comparison to the old failed strut that just worked as a support.
Rodder is offline   Reply With Quote
Old 05-07-2011   #14
You got that right
Carter,the easiest way to get the small cylinders on is with some help,disconnect the main strut.This will allow the hood to got forward enough the slip the short cylinders on the studs.Out of the box the short cylinders are abut 3/4 on an inch too long to slip on the studs with the main cylinder connected and compressing these by hand aint gonna happen.
Old 05-09-2011   #15
carter200
carter200's Avatar
Jeff,
Thanks, I appreciate the heads-up on the install.
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
