Old 04-22-2011   #11
Default Re: Plenum and Cam Cover bolts
Another option would be to take your torx heads, punch holes in a box....put the bolts in the holes and paint them with high temp semi gloss paint. Unless you mean they are stripped out
Old 04-25-2011   #12
Daniel_Mc
Daniel_Mc's Avatar
I painted the cover myself, you can also powdercoat it....
I am in the middle of restocking emblems....have one set of 91-95 left
I own the 1990 the that Laurence Bussey owned prior to buying the 91 Kim Baker car....
LGAFF,
I prefer to do things myself and this seems like an easy thing to do as long as prep is done properly. I was thinking sodium blasting the parts to remove the old coatings and then painting. Would you see any drawbacks to the sodium blasting? I will PM you on the emblems.
The 90 Buzz had was his DD for a good time, if I remember correctly? Is this the same car you had the Gen I Dymags on?
The torx heads are not stripped (well to my knowledge they are not I have not seen the car I am having it shipped directly to the NCM and I will pick it up on the 10th or 11th of May when I drop the GS off on loan again.) They just look like they have some surface rust on them.
I'm guessing probably not as not that many people have Black Widow motors.....
But you can easily find them elsewhere if you know what to ask for...
http://www.boltdepot.com/dimension.a...25&cs=81&cm=23
http://www.nutsandbolts.com/bolts-me...-c-31_164.html
http://www.fastener-express.com/metr...loy-steel.aspx
Make sure to ask for alloy steel with the oil black finish.
TomC
'Crabs
Tom,
Thank you Sir! These links are going to help if anything is stripped
Daniel
Daniel_Mc is offline   Reply With Quote
