Go Back   ZR-1 Net Registry Forums > Club Regional Areas > Mid-Atlantic Region
Old 04-18-2011   #11
secondchance
Default Re: Westminster MD - WMD on Sunday April 17
Originally Posted by QB93Z View Post
We had a great ZR-1 Day!!!
We replaced injectors and coils in two ZR-1's and then pulled a transmission to replace the clutch disc and replace the transmission input shaft seal which was leaking so bad that it was causing the clutch to slip.
Thanks to David, Bill, Yun, Darrin, Paul, Rich and Glenn for making it a sucessful day.
Don't forget Dr. Phil.
Old 04-18-2011   #12
QB93Z
QB93Z's Avatar
I am so sorry. I did forget to include Phil on the list. Thanks Phil.
Old 04-18-2011   #13
Unbelievable help to z brothers
Special thanks to Darrin and Jim. They are the ones going above and beyond! They are what make wazoo special!!
Thanks guys!!!!!
Old 04-18-2011   #14
secondchance
Thanks guys!!!!!
Here! Here!
What was it? Around 3 pm? Darrin goes, after injector changes to two cars, "what do you say guys - drop trannie off of Paul's car and see where the oil leak is?". Darrin's favorite line - "mass creates torque!!!".
Old 04-19-2011   #15
QB93Z
QB93Z's Avatar
So, Ron came to the garage while we were removing a transmission and says: "You ought to get a transmission jack."
Jim answers: "I have a transmission jack. It is called Darrin."
Old 04-19-2011   #16
Scrrem
Scrrem's Avatar
Pics...
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
